View Full Version : Miscellaneous BH350 fax kit
KM7155
07-24-2012, 02:56 PM
Hi Guys,
some question regarding the FK50s for B350.
what is the purpose of the battery and the memory?
i try the fax without these 2 items, the fax is working.
im lost why we need to buy the memory and battery which is not needed for the fax function.
Shadow
07-24-2012, 03:03 PM
the battery is for maintaining your programed numbers and settings should you have a power failure or the cleaners unplug the machine.
the memory is for sending larger documents and memory sending during later hours of the day/night when long distance rates are lower.
KM7155
07-25-2012, 02:47 PM
i heard the battery is for Di3510 model only.
i did try to unplug the power and leave the machine without power connected for 1 hour,
after restart, my programed number still there.
ck1
07-26-2012, 02:19 AM
No bizhub if you but the fax kit come with the battery . but no battery also can work ( i buy used fax kit without battery ) memoey is for IP fax only
