View Full Version : Cf2002 fusing unit reset
ingridmv
12-14-2007, 06:47 PM
is there a way to re-set the fusing unit on a Cf2002 without purhasing a new one??
wagon
12-14-2007, 08:30 PM
There is a 50mA fuse (with wires) hiding up inside the fuser. Be careful, things are quite fragile (lamps and such).
bigpa
02-11-2008, 06:59 PM
Thanks for the advice but I can not find the fuse, you would not have a scheme?
PS excuse my English machine translation from Italian on google
danito0203
02-12-2008, 07:38 AM
hello.
did you find the way for reset cf2002 fusing unit?
need help also, can't find the fuser.
txs a lot
bowser
04-10-2008, 01:18 AM
the fuse is a 1/16amp pico fuse and is behined the connector
remove the back panel of fuser be careful it is a loop back wire covered with heat shrik rubber tubing in the connector
charlie eglinton
04-17-2008, 09:30 PM
Hi:
1.Where can I get the fuse, RadioShack? Or from Konica-Minolta.What is the parts # then?
2.Could you also clarify/ confirm :confused: 1/16amp pico fuse and not the 50mA fuse as mentioned by another member?
Thanks.
bowser
04-19-2008, 03:47 AM
yes a 1/16 amp fuse ill get part #
charlie eglinton
04-26-2008, 06:12 PM
Still waiting for the parts No. As it should be cheaper than buying a fuser reset module that allows you to reset the Fusing Unit instead of replacing it.The cost of the unit is $75.00 and only requires a new 200 mamp fuse ($1.00/each) each time you reset a fusing unit.(info obtained from the following site:Copy Life - Your supplier for IU boards for color copiers (http://www.copylife.us) )
Any experience/feedback :)with this reset module,please share. We have both CF2002 and KM 8020 in this office.Thanks.
