View Full Version : Bizhub C452/552 image unit
Can the image unit be chipped on c452/552 and where does it go on the unit? I stripped the nit but i cant find where the chip should go.
Thank you.
Avskrap
08-01-2012, 09:54 AM
The imaging units that are in the machines from the factory seems unchippable. Atleast that's what we've found. The replacement units you order does have the chip in the same place as the C451/C550 ones.
We change the units at the first interval, then chip them at the next (depending on wear, etc).
kingarthur
08-01-2012, 10:31 AM
The m/cs come from the factory without chips, but was thinking of putting a chip where there should be one...just to see if it would reset....
pepper38_cnd
08-01-2012, 11:34 AM
The replacement CYM units can be re-chipped although getting the chip in and out is not easy. It is much easier to reset the chip while it is still in the IU.
emujo
08-01-2012, 01:36 PM
Beating a dead horse here....install the PPLM firmware, you don't have to re-chip, refuse anything...Units run untill CQ issues require replacement..Emujo
Darren King
08-01-2012, 06:03 PM
This firmware is great. You just have to make sure you keep the consumables on hand as when they are done, they need to be replaced!
Avskrap
08-02-2012, 10:20 AM
I didn't know about that FW... Hmm. Do you have a document ID for it? I would be ever so grateful.
