View Full Version : Miscellaneous how to repeat image 6 times in c220
r_burhan
08-05-2012, 12:17 PM
We have just purchased a Konika Minolta C220. But we are getting option of only 2/4/8 image in "Duplex/Combine" as well as "Image Repeat" option. We want option of 6 images in combine or image repeat. How to add option of 6 image or if there is any other way of repeating image 6 times. Please help!!!!
blackcat4866
08-05-2012, 09:02 PM
The functions on your MFP were designed and implemented by engineers, not technicians. There are a lot of things I'd like to change about the operation panel functions, but alas, we all just try to live with the functions that we are provided. =^..^=
r_burhan
08-07-2012, 05:54 AM
Thanks for your reply..Can you provide any trick/tweak to help me.....its really important...Thankss...
kingarthur
08-07-2012, 08:44 AM
There aren't any....as far as i'm aware....dont think any m/c can do what you want....contact the people who supplied it
Dickie
08-07-2012, 10:03 AM
It's easy:confused:
1. do an 8 times image repeat.
2. Get pair of scissors.
3. Cut 2 off the page and throw away.
Job done easy peasy lemon squeezy:D
blackcat4866
08-07-2012, 10:07 PM
It's easy:confused: 1. do an 8 times image repeat. 2. Get pair of scissors. 3. Cut 2 off the page and throw away. Job done easy peasy lemon squeezy:D Damn! You beat me to it. =^..^=
r_burhan
08-12-2012, 10:55 AM
There aren't any....as far as i'm aware....dont think any m/c can do what you want....contact the people who supplied itI got the below mail from Konika support, but unable to fulfill my objective. Pls help....""In order to make 6 image repeated copy, please do as follows.- go to image repeat menu- "set range" in "scan range"- select "custom size"- input the size of document so that it is equal to 1/6 od print sizee.g. x=105.0mm y=99.0mm (in case print size is A4)- go to copy main display- select A4 size paper for example then start copyFoe the detail, please refer to image repeat in chapter "Application" of the copier user manual.""
r_burhan
08-16-2012, 09:07 AM
yippeeee...done!!!!
habik
08-16-2012, 09:11 AM
yippeeee...done!!!!
So which one was it. Paper, Scissors or Stone
Mita-Konica-Tech
08-17-2012, 01:51 AM
It's Scissors, Rock, Paper....or is it Rock, Paper, Scissors...? Must be British..."Stone"
blackcat4866
08-17-2012, 01:57 AM
Czech Republic, but I think he's educated UK. =^..^=
habik
08-17-2012, 12:29 PM
And maybe I am just thinking alphabetically and in Slovak we use stone :D
