View Full Version : Bizhub 36/42 Hard Drive Size problem
Bullet71
09-11-2012, 02:43 PM
Hi need to know how to solve issue with a B36 showing hard drive size as 20gb. This causes fax to freeze and a few other issues. The machine has a 320gb hard drive. I have done firmware and a mode 8 complete format yet drive still shows 20gb. I have the same issue with a C35 and believe it is a common problem on the new smaller range. How do i resolve this Please help.
JustManuals
09-11-2012, 03:38 PM
Paul@justmanuals.com
blackcat4866
09-11-2012, 07:38 PM
Do you have another machine you can swap hard drives with, just for diagnosis? It's most likely a HDD failure, but this way you can be sure. =^..^=
Bullet71
09-12-2012, 06:10 AM
Tried that still does the same so not the hard drive.
emujo
09-12-2012, 06:36 PM
I just printed a config sheet from our b42..shows 20470MB, HDD" installed", but directly under this is shows "10MB" used, you're not mixing these 2 items up...
Bullet71
09-13-2012, 06:18 AM
The machine actually has a 320Gb drive in 20470mb is only 20 GB.
emujo
09-14-2012, 07:42 PM
You are correct..never noticed that..but did some checking and the 20k (20GB) is what's available for doc storage. The Bizhub config sheet shows 120GB drive installed but I'm sure you are correct on the new devices with 320 gb hdds. So what happened to the other 200GB+??? The general consensus around here is that the rest is used for print/scan/fax. Try freeing up some doc storage space and see what happens. Emujo
Chip Resets SA
09-15-2012, 08:24 AM
Unplug hard drive from control board "with machine off" switch machine on without hard drive plugged in and wait for ready to copy, ensure job log is empty on all functions, fax, cop, print and scan. Switch machine off plug hard drive in restart.
