View Full Version : canon ir c3220 warm up
pontiac
10-09-2012, 07:02 PM
We have 2 3220 that have the same issue. copiers stay in warm up mode, i have replaced fuser assembly, same problem. No error codes. Any thoughts thanks
doktor
10-09-2012, 07:53 PM
http://www.copytechnet.com/forums/canon/35739-canon-irc3200-warming-up-continuously.html
http://www.copytechnet.com/forums/canon/39384-canon-irc-3220-keep-warming-up-after-replace-new-magenta-drum.html
http://www.copytechnet.com/forums/canon/40732-canon-irc-3200-warming-up.html
http://www.copytechnet.com/forums/canon/59276-irc3200-printer-warming-up-stack.html
Will it be enough ?
Canon.Tech
10-10-2012, 09:32 AM
If the machine shows "printer warming up" leave the machine on it will eventually show an error code, might take about 15 minutes.
Report back the code here.
pontiac
10-13-2012, 02:56 AM
doktor you nailed it, We had two bad drums one cyan and one magenta when i spoke to our other tech who did one of the copiers we put 1&1 together. Thanks a bunch guys for replys.
ericang
10-13-2012, 05:00 AM
check toner n make sure is not near to empty for each cartridge
check System Monitor>Comsumables n make sure your toner chip all are still useable....
hav this experienced before...
my cust called n told me that the cyan is finish n request for a replacement cartridge..
went there n replace the chip only because there are still some toner in the cartridge...
next day customer called again n told that the mc keep warming up... n they waited for halfhour
LoL
change with new cartridge n chip... problem Solved
