View Full Version : Error Code canon
good day guys. please i have this problem with this costumer machine by make canon Ir 2200 that is giving me this error code E000000-0000 please any hep will be grateful thank for your consent.
zoraldinho
10-10-2012, 04:06 PM
The reading of the main thermistor does not reach 30°C
-The fixing film unit is faulty
-The main thermistor has an open circuit
-The fixing heater has an open circuit
-The main power supply PCB is faulty
-DC controller PCB is faulty
To reset the error, execute the following in service mode:
COPIER>FUNCTION>CLEAR>ERR.
Rachid.Akli
10-10-2012, 07:12 PM
-E000: The reading of the main thermistor does not reach 30°C 1 sec after the main power switch is turned on. Or, it does not reach 70°C 2 sec thereafter.
===>This may occur when the busbar voltage falls below 10% of its optimum value.
-The door switch may be faulty.
If you cannot clear the error as proposed by Zoraldinho, start by changing the film assembly (film+resistor) and don't forget to reset the error.
Rachid
