View Full Version : Jamming CANON IR c2880 Jamming at registration.
rexctacy
10-11-2012, 03:04 AM
hi there all.
i am a qualified service technician who is currently trying to nut out a problem on a Canon Photocopier (usually look at kyocera and panasonic)
the problem that i am having is when paper is goin to be fed it only exits the cassette about 1 or 2 cms. i cleaned the pickup and separation rollers. and this helped to the point where all documents fed in to the copier are stopping at the registration section. the copier has almost done 400000 copies and are thinking that the rollers are worn. i am not very familiar with this machine but it also looks like the registration flag has worn due to paper passing over it. (could this be true?) feed rollers in this machine were filthy and have all been cleaned. is there a maintenance kit available for this machine? and if so what does it involve/include.
any help would be appreciated. :D
zoraldinho
10-11-2012, 07:23 AM
Read post......http://www.copytechnet.com/forums/canon/6925-canon-ir4570-3570-2270-etc-jammig-right-door.html
Rachid.Akli
10-11-2012, 08:06 AM
Hello,
Repport the Jam code from: Service mode > Copier > Display > Jam.
Is it the same when using the bypass and the second cassette?
Rachid.
Canon.Tech
10-11-2012, 09:19 AM
First step is to replace the pick up, feed & separation roller, cleaning helps but is only a quick fix.
The registration flag can wear down if it is the old plastic type (it has been modified with a metal tip)
Also check the cassette dial is set to the correct size. e.g if the tray has A4 paper in & the dial is set to A4R the machine will jam.
I can supply you with said parts if rquired, as a test you can swap the rollers from another port, e.g A3 is not used as much & rollers are usually not worn.
CanonSco
10-11-2012, 08:33 PM
I echo what Canon.Tech has said.
Some more info would be good first. Jam code. Same all cassettes and paper sizes. etc etc,
Also on this machine, double check main door lower pin on the door side. The pin receptacle on the lower RHS of the door is plastic and can break. This can cause some nice jams.
teckat
10-11-2012, 09:21 PM
a way to improve the stability of pressure applied by the vertical path roller to prevent jam code 0105.
If you have an imageRUNNER device which is experiencing a jam code 0105 , replace the old type parts with the new type parts listed
Replacing the Right Lower Door Assembly/the Right Lower Inner Door Assembly:
see pdf------:cool:--17627
CanonSco
10-11-2012, 10:01 PM
2880 not come with those type door / guide anyway?
teckat
10-11-2012, 10:30 PM
poster quoted
Sorry, but you are wrong> that repair is for
Color imageRUNNER C2880
Color imageRUNNER C2880i
Color imageRUNNER C3380
Color imageRUNNER C3380i
Have done it many times on those listed effected models:o
A change has been made to the member helping the vertical path roller applying pressure from the right
lower door sheet B to an inner door pressure plate [C]. (Change in the pressure application mechanism of the vertical path roller).
[B]P-2 OLD TYPE ///// P-3 NEW TYPE
[B] Right lower door sheet B [C] Inner door pressure plate
[1] Right lower inner door ass'y
CanonSco
10-12-2012, 12:08 AM
Never seen a 2880 without those ( new type ) door / guide. Even from install.
Or in other words never seen a 2880 with the old 4570 type guide / lower door.
teckat
10-12-2012, 05:21 AM
Products Affected: ---------Serial Numbers Affected:
Color imageRUNNER C2880 ---JUH00001 ~ JUH02169
Color imageRUNNER C2880 V2 --MNP00001 and Later
Color imageRUNNER C2880i ---JUJ00001 ~ JUJ02635
Color imageRUNNER C2880i V2 --MNW00001 and Later
Color imageRUNNER C3380 ---TXN00001 ~ TXN02065
Color imageRUNNER C3380 V2 --MMN00001 and Later
Color imageRUNNER C3380i ---TXP00001 ~ TXP03102
Color imageRUNNER C3380i V2 --MMP00001 and Later
had updated many of these affected serial numbers on East Coast >USA ;)
zoraldinho
10-12-2012, 07:40 AM
IR2880c old type
IR2380c new type
CanonSco
10-12-2012, 07:42 AM
I don't doubt it. Strange though. Got to say I don't recognise those serial numbers. Perhaps was different in the US over UK/EU. Any UK/EU techs had to change the old style guides on a 2880?
The OP should certainly take heed if he has the old style lower door and guide.
Dan Dryer
10-12-2012, 02:46 PM
A few of the earlier 2880s had the old type lower door and guides. Only a very small number though.
zoraldinho
10-12-2012, 04:40 PM
Affected Machines:
iRC2880 120V : JUH02170 and later
iRC2880 230V EUR : JUL00872 and later
iRC2880 230V : JUT00010 and later
iRC2880 230V AU : JVB00483 and later
iRC2880 v2 120V : MNP00001 and later
iRC2880 v2 230V EUR : MNY00001 and later
iRC2880 v2 230V : MPA00001 and later
iRC2880 v2 230V AU : MRA00001 and later
iRC2880i 120V : JUJ02636 and later
iRC2880i 230V EUR : JUM14076 and later
iRC2880i 230V AU : JUZ00365 and later
iRC2880i 220V CN : JVD00029 and later
iRC2880i 220V KR : JVE00241 and later
iRC2880i 120V TW : JVC00018 and later
iRC2880i v2 120V : MNW00001 and later
iRC2880i v2 230V EUR : MNZ00001 and later
iRC2880i v2 230V : MQA00001 and later
iRC3380 120V : TXN02066 and later
iRC3380 230V EUR : TXR00638 and later
iRC3380 230V : TXT00024 and later
iRC3380 230V AU : TXV00588 and later
iRC3380 v2 120V : MMN00001 and later
iRC3380 v2 230V EUR : MMR00001 and later
iRC3380 v2 230V : MMT00001 and later
iRC3380 v2 230V AU : MMV00001 and later
iRC3380i 120V : TXP03102 and later
iRC3380i 230V EUR : TXS04652 and later
iRC3380i 230V : TXU00630 and later
iRC3380i 220V CN : TXX00042 and later
iRC3380i 220V KR : TXY00091 and later
iRC3380i 120V TW : TXW00018 and later
iRC3380i v2 120V : MMP00001 and later
iRC3380i v2 230V EUR : MMS00001 and later
iRC3380i v2 230V : MMU00001 and later
Dan Dryer
10-12-2012, 05:29 PM
Affected Machines:
Most of those serial numbers don't apply to the UK/Europe, and of the ones that do, only a tiny percentage were sold in the UK.
I remember the training machine having the old style door and guide, but in the field I've seen maybe 3 or 4 at the most.
rexctacy
10-15-2012, 12:18 AM
hi there, thankyou everyone for your helpful info. i tried replacing the roller from the lower cassette (A3) but i looked like the last tech that looked at it had already swapped over rollers. the flag is the plastic type without the metal tip. cassette dial was set correctly. does anyone have the part numbers for the pickup, feed and sep rollers? also the part number for the registration switch (new modified part).
i was also reading teckat's post about replacing the right lower door assembly. ithink the machine needs this mod aswell. the serial number is JVB00***
teckat
10-15-2012, 12:51 AM
2- Cassette feed rollers / FC6-7083-000
2-Cassette separation rollers / FC6-6661-000
registration switch ???
rexctacy
10-15-2012, 02:15 AM
Sorry, registration flag sensor
rexctacy
10-15-2012, 02:45 AM
sorry to be a pain in the ass but
does anyone have the service and parts manual for this machine.
we have access to the cipg manuals but not the bisg.
Canon.Tech
10-15-2012, 09:06 AM
I have PM'ed you the manuals :)
rexctacy
10-16-2012, 02:49 AM
thanks for doing that.
it is slow but i will eventually get what i wanted so i cant complain.
Canon.Tech
10-16-2012, 08:52 AM
No worries.
Seems to be faster if you right click the link & choose "save file as" rather than click on the lick & wait for it to open.
rexctacy
11-13-2012, 06:00 AM
Problem is now sorted. thanks goes out to all that have helped me.
customer is stoked.
thread can now be closed
:)solved:)
teckat
11-13-2012, 03:11 PM
customer is stoked.
:)solved:)
explain what procedures u did ???/
threads are never closed-------------
rexctacy
11-13-2012, 11:59 PM
replaced feed and separation rollers in cassettes. fitted modded lower right inner door assembly and also replaced registration flag sensor. machine tested ok
canontech1
05-15-2017, 02:52 PM
thanks for this thread it helped
