View Full Version : clc 4000
Luther
10-15-2012, 10:03 PM
I have a clc 4000 that for some reason wont let me pull the transfer belt assembly out,i lower the lever and pull and its stuck, is there another release or has anyone seen this before?
teckat
10-15-2012, 10:49 PM
power off printer>
lift up hopper>
release T/B handle>
see if u can slide out the drum/dev unit ?
if u can> now try to slide out the T/B Unit while drum/dev unit is out---
T/B unit may not be sitting on slide rails correct
Luther
10-15-2012, 11:28 PM
drum unit slides out fine, installed new drums today and when i went to pull the t/b unit it was stuck, ill give that a try tomorrow
charm5496
10-16-2012, 05:14 PM
sounds like the shipping screws are installed in the ITB frame.
When you drop down the handle do you see the belt cam down at all or is it still flush with the drums?
teckat
10-16-2012, 05:31 PM
good point on T/B lock in screws /
if the T/B cams do not fully rotate when handle is released/
u will have a headache issue to deal with
u will then have to remove all Drums/Dev's. completely to inspect that T/B UNIT
