DANIELCANON
10-18-2012, 05:42 PM
Hola a todos necesito el codigo de la tarjeta de interface de comunicacion entre la copiadora y el servidor imagepass S2.
SI ALGUIEN PUEDE ENVIARME TODOS LO ACCESORIOS QUE SE NECESITAN Y EL PROCESO DE LA INSTALACION.
Lo que pasa es que nos a llegado un servidor S2, el cable de comunicacion, el cable de red, y dos tarjetas, una es de bus pero la otra parece que no es la adecuada porque el cable es mas pequeño que la ranura de la tarjeta que deberia ir en la copiadora.
178071780817809
teckat
10-18-2012, 07:34 PM
178071780817809
Hi all I need the code card communication interface between the copier and the server imagePASS S2.
IF ANYONE CAN SEND ME ALL THE ACCESSORIES NEEDED AND THE INSTALLATION PROCESS.
What happens is that we got a server to S2, the communication cable, network cable, and two cards, a bus is but the other seems not appropriate because the cable is smaller than the slot card that should go into the copier.
see attached pdf's:rolleyes:
U need the Copier interface board for the Printer Model u intend to connect S2
FM2-5433-000 = OPEN INTERFACE BOARD PCB ASSEMBLY
FM2-5430-000 = PCI BUS CONNECTOR PCB ASSEMBLY
FE1-6168-000 = VIDEO PCB ASSEMBLY
The imageRUNNER 7105/7095/7086/7095P machines support 1200 dpi image transfer, thus the imagePASS-S2 is connected using a Video cable and Ethernet crossover cable.
However, the imageRUNNER 8070/6570/5570/5070 do not support 1200 dpi image transfer and as such are connected using an Ethernet crossover cable only.
A video cable connection is added to the engine along with the conventional Ethernet cable connection.
-In order to use the Video cable connection, an Interface board and PCI BUS board are supplied with the controller.
The PCI BUS board connects between the Interface Board and Video Interface Board of the
controller.
When the controller is installed, installation of the Interface board and PCI BUS board is needed to connect an engine.
When you equip the PCI BUS board in an iR5075/5065/5055/5050, you need to replace the existing plate with the packaged plate. For replacement details, please refer to the installation procedure.
Note – The packaged PCI BUS board may come quipped in iR7105/7095/7086/7095P as standard.
imagePASS-S2 = 0494B007AA
Software
FE1-6180-000 /imagePASS S2 System Software CD1
FE1-6181-000 /imagePASS S2 System Software CD2
FE1-6179-000 /imagePASS S2 Media Pack
Connectivity Accessories
0123B002AB - Hot Folder
6596A023AA - IMPOSE v2.6
Accessories
FE1-6067-000 Motherboard PCB Assembly
FE1-6168-000 Image Controller PCB Assembly
FM2-5430-000 Riser Board PCB Assembly
FE1-6095-000 UIB PCB Assembly (RoHS Compliant)
FE1-6071-000 256MB DIMM
FE1-6068-000 CPU Unit w/Cooling Kit
FE1-5978-000 Cooling Kit
FE1-6073-000 80GB HD
FE1-6052-000 Fan, Front
FE1-5741-000 Fan, Back Panel or Rear
FE1-6100-000 CD ROM Drive Unit (RoHS Compliant)
FE1-6105-000 Power Supply (RoHS Compliant)
FE1-6075-000 Front Panel Unit w/UIB
FE1-6077-000 Cover, Left
FE1-6078-000 Cover, Right
FE1-6076-000 Cover, Top
FE1-6079-000 Cable, HDD
FE1-6162-000 Cable, CD ROM
FE1-6081-000 Cable, UIB
FC7-4258-000 Mount, PCB (iR5075/5065/5055 Series)
FC6-7150-000 Mount, PCB (iR7105/7095/7086 Series)
FK2-1635-000 Cable, Copier I/F
FE1-6053-000 Cable, Crossover
FE1-6103-000 Power Cord, 120V (RoHS Compliant)
