View Full Version : Miscellaneous Insert covers in copy mode on C364 ?
jazzfan1980
10-25-2012, 04:56 PM
Hello,
I had an opportunity to see a bizhub C364 in action, but could not get the full applications menu in copy mode. Some features were missing, like the "insert cover sheet" seen on the C454.
Is it due to some parameters in the admin section or is this a limitation due to the firmware of the equipment ?
Thanks in advance for your answer !
Lionel
TheOwl
10-26-2012, 12:12 AM
Hello,
Lionel
Lionel, the C364 Series machines are capable of using the Cover Sheet mode.
1. Copy
2. Application
3. Scroll to the right until section F) where you will find Cover Sheet
B0265
10-26-2012, 11:19 AM
Check this setting: Admin - System - Custom Display - Custom Function Pattern
jazzfan1980
10-29-2012, 05:39 PM
I do not have access to a C364 right now but I will check this next time.
Thank you very much for your answer !
Lionel
