View Full Version : BH600 Second Side background
JR2ALTA
10-30-2012, 12:08 AM
Both sides clean on a simplex print.
Duplex prints have background on second side only.
Tried transfer unit.
I will try HV board next.
Voltage should adjust for the second side, so I am guessing there is something whacky going on.
Has 1.5 million on it.
Thanks in advance!
Thanks in advance!
Seen this happen when way over pm cycle. Also when adjustments are off most often Ld1 Ld2. This use to happen on the old 7255 all the time from a bad drum ground.
JR2ALTA
10-30-2012, 03:05 AM
Seen this happen when way over pm cycle. Also when adjustments are off most often Ld1 Ld2. This use to happen on the old 7255 all the time from a bad drum ground. What did you do for the bad drum ground?
JustManuals
10-30-2012, 04:23 AM
Paul@justmanuals.com
JR2ALTA
10-30-2012, 06:56 PM
Ld1 and ld2 thanks!
