Staffan
11-08-2012, 09:11 AM
Hello.
I have a problem with a Ricoh MP C7501.
The machine has about 200,000 in color and 50,000 in the black.
I get banding in all four colors.
I go into the SP2-109-2 Select Pattern and choose 100% Coverage.
Then I set these values:
SP2-109-05 Density: K to 15
SP2-109-06 Density: M to 0
SP2-109-07 Density: C to 0
SP2-109-08 Density: Y to 0
Enters the Copy Mode, choose Color, choose A3 (with coated paper), running an A3 with 100% coverage.
Proceed as with all four colors by changing the density so that I only get one color for each PCU.
Each paper look the same those first 48 mm, perfect coverage.
Then starts banding...!!!
The banding donīt show any repetitive/periodical/recurrent patterns.
I have changed these parts in all four PCU / Devunit:
Developer.
Drum.
Both CL-Blade
CL-Brush.
Coatningbar.
I have cleaned Dr. Blade.
I have changed these parts in the Image Transfer Unit:
All four Image Transfer Rollers.
Paper Transfer Roller in the ITB Unit.
The cables from the Transfer Rollers down to the Power Pack.
The actual Powerpack.
Bearings on both sides (and therefore cable from Paper Transfer Roller to PowerPack) of Paper Transfer Roller in the ITB Unit.
Both CL-Blade.
Both CL-Brush.
Coatingbar.
I have changed these parts in the Paper Transfer Unit.
Paper Transfer Roller.
Coating Bar.
Both CL-Blade.
Both CL-Brush
Now I'm out of ideas, what can cause this.
Maby the paper starts to go unstable when it comes over to feed between Paper Trasnfer Unit and Fuser-unit.
But is not 48 mm between Paper Transfer Unit and the feed after that, it is too short.
I'm more into that the Power suply Board can not provide enough power to the BIAS-rollers in the developer unit and / or Paper transfer Rolers.
All modifications are made, it's newest software.
Please, is there any ideas!
Developer.
Drum.
Both CL-Blade
CL-Brush.
Coatningbar.
Both CL-Blade.
Both CL-Brush.
Coatingbar.
Coating Bar.
Both CL-Blade.
Both CL-Brush
