View Full Version : Error Code SC322 on ricoh mp201
Gesttech
11-08-2012, 02:51 PM
Hi All
i have a client that have been open a business,
they have check the electricity for all room but they forget to switch off the printer mp201spf
When they switch on the breaker the machine switch on and the sc322 occurs.
Pls can someone can tell me how the bicu been damaged wjth the SC322, i already check the LD unit & toner supply its ok.
i need to inform the client how it occurs. how to explain that?
PinevskiS
11-08-2012, 06:13 PM
Hi All
Replace DRUM UNIT , you have problem with charge roller.
I have this problem many times.
JustManuals
11-08-2012, 06:29 PM
Paul@justmanuals.com
M0scb
11-10-2012, 04:45 PM
SC322 is realated to the laser sync detection. (see attachment) I would suggest that when the power was turned off, the machine was writing information to or from one of the pcb's. If you have access to a spare machine, you could try swapping out the synd board, laser and BICU.
johnyb
11-11-2012, 09:51 PM
HI
You get SC 322 when the toner bottle isn't inserted...
Cheers
kannuki2
11-26-2012, 10:10 AM
Yes agreed, I came across that two times already. I would try to load new engine and system firmwares on it.
Polarbear
11-26-2012, 12:37 PM
HI
Cheers
I think you mean toner HOPPER?!
racikram24
11-29-2012, 04:46 AM
Usually SC322 is a problem with Laser Sync. (Laser Box Unit / Write Unit).
Try to change that particular part, it might the one giving you the headaches. :)
johnyb
12-01-2012, 10:55 PM
ER No I didn't mean Hopper, I meant toner bottle!!!!
Copied from FSM!!!
• Toner bottle not installed
• Loose connection between the LD unit and the BICU
• Defective cable between the BICU and LD unit
• LD unit out of position
• Defective LD unit
• Defective BICU
Debs1964
12-02-2012, 12:07 AM
Can you check SC code history in SP mode. I had an MP201 with a similar code (it's late and I've been at the hospital all day with my dad so I'm not looking it up today), I replaced LD and BICU, it immediately burnt out the new BICU, when SC history was checked there was another code (not displayed on panel), fault was caused by the scan motor.
I'll look up what the actual codes were tomorrow if I remember
Debs1964
12-02-2012, 12:51 AM
OK, I was still up, waiting for a call from the hospital, so I looked it up this evening.
The machine I had would display a paper jam (no jammed paper), then SC320 would occur. When SP7403 was checked, SC121 had occurred at the same time as SC320.
Scanner motor and BICU needed replacing
Hope this helps
