View Full Version : Ricoh MP C2500
iscott
11-08-2012, 03:58 PM
In Service mode / Original Jam History / What sensor does 004 Indicate?
Eric1968
11-08-2012, 04:24 PM
Skew Correction Sensor, if my memory serves me right. But you can also print SP5-990-4 to see what sensor is registering the jam.
JustManuals
11-08-2012, 06:40 PM
Paul@justmanuals.com
SargeNZ
11-08-2012, 10:50 PM
What is also handy when troubleshooting sensors is to go into periphs > ADF > INPUT CHECK and make each sensor changes from 00000000 to 00000001 when you place your finger over them. Also gives visual confirmation of the sensors location.
If it is Df you have problem with the sensor might be ok but the patch for the sensor will be covered in paper dust so checking the sensor with a finger will not help.Clean all patches 1st.
kannuki2
11-22-2012, 03:47 PM
Most of the time, that jam code is caused by the DF feed clutch. Open the Df rear cover and run about 20 pages duplex and apply some pressure on the clutch's shaft. If it stops, then you know you need some good cleaning or a new one.
