View Full Version : Bizhub 250 (black n White)
big jase
11-08-2012, 07:57 PM
i have a strange one, intermitantly when copying we get a total Black copy , if you recyle the power the machine runs fine again till the next time!
This can be fine for a wek or two but then can also fail within the hour:confused:
Darren King
11-08-2012, 08:16 PM
What have you done to try to fix the problem? I don't want to suggest things you have already done.
Darren
big jase
11-08-2012, 08:37 PM
Darren
tried replacing drum unit (full unit inc dev ) , re flashed firmware , reseated all connections on mfp
Darren King
11-08-2012, 08:52 PM
Check contacts inside drum unit opening. Check connectors on high voltage board
blackcat4866
11-09-2012, 01:01 AM
I was thinking more along the lines of exposure lamp failing to light or primary charge loss. Can you reproduce the problem? =^..^=
wseyller
11-09-2012, 02:10 AM
Does it happen only when doing a copy or also when printing. I usually go into Function and run the F12 test pages to eliminate the scanner.
Sent from my XT875 using Tapatalk 2
Hansoon
11-09-2012, 07:26 AM
Something like that.
Hans
