View Full Version : Ricoh 240w led head is it same as MP w2400 led head?
copierpro
11-13-2012, 09:21 PM
I don;t have the parts manual for the w2400 but is the led head for the 240w B125 1859 interchangeable with the mp w2400 led head?
Parts manual calls for the B286/LW324/2404WD/MPW2400 to use the same head part# B2861860. Major changes were made to the 2400w so I do not think you can adapt it to work. Good luck
copierpro
11-14-2012, 12:40 PM
What is the B286 1859 listed for w2400? Note the 240w uses B125 1859.
My manual does not show that part number at all. It shows all of these machines use part# B2861860--- B286/LW324/2404WD/MPW2400
I guess I could have an out dated manual but that is what I have.
copierpro
11-14-2012, 09:36 PM
OK, thanks. Removed the LED head and the three LEDS are B125 1997 part numbers on this B286 1860 LED head. I think the ground is different. The 240w manual shows one ground and this led has two braided ground cables.
Thanks for getting back with the info --- I'll make a note of that one.
copierpro
11-16-2012, 07:22 PM
By any chance you know where I can get a CIS lamp for the CIS unit for the MP w2400/3600? I need one that has broken pin, furthermost right lamp.
Sorry but I can not help you with that one. I can get you a new one from Ricoh but I do not know at what price. If it will help you I can send you a copy of the parts manual just give me an email address to send it to.
copierpro
11-16-2012, 08:36 PM
thanks support@copiergeeks.biz
