View Full Version : C451 Missing Utility
Capodastra
11-28-2012, 10:42 AM
My Bizhub C451 is missing No. 5 (Controller Settings) in the Utility (Untility/Counter) menu.
Please can anyone tell me how to get it back . . .
and . . .
how can I change the IP address of the Fiery?
Would be grateful for any help/advice.
C
emujo
11-28-2012, 06:01 PM
If you have the MFP programmed correctly (Image controller setting at 1), then you should get a please power on controller message when you 1st turn on the MFP and controller. You won't see the controller (#5) until it boots. If you are able to print from the controller normally but still don't see the controller menu, then you will probably need to do a re-init, to get the MFP back to factory, reload firmware then go back and set your image controller back to 1. Let us know...Emujo
Capodastra
11-28-2012, 07:29 PM
Thank you so much for your help.
You might need to explain that in simpler terms as I am a novice.
I am on a Mac and linked via a hub. One cable going to the Lan input in the Fiery and another cable from the hub direct to the copier (this allows me to use both).
I have shut down and restarted and the controller appears as #5 in the list. I am running set up again to make sure.
Please explain what the MFP is. Is re-init = reinitialise? . . and by that do you mean reboot the system? If so, then I have done that and the controller is now #5 in the list. Thanks!
How do I alter the IP address in the Fiery?
Sorry to be vague, this seems a bit technical for me . .
C
Setright
11-30-2012, 08:42 AM
MFP = Multi-Functional-Printer :D
The controller and the MFP have lost contact. You need to switch both OFF, then start the controller FIRST and give it a 30 second headstart before switching on the MFP.
MFP has a main power switch behind a little white door, next to the cassettes, use this switch.
The controller has a green light, that is also a button. Hold the button in for more than 2 seconds to shutdown. Then press briefly to start it again.
Capodastra
11-30-2012, 11:10 AM
Sorted. It appears now.
Can you explain how I can change the ip address of the Fiery if I have future issues.
Many thanks
C
emujo
11-30-2012, 08:53 PM
On the LCD of the MFP, select #5 Controller details
On the new screen you should see the Fiery MENU icon, touch it, using the up/down arrows find the icon for setup, then touch the icon next to OK. It may ask if you are sure? select OK and the Fiery will re-boot and come up with the password screen. Enter the Admin password ( I don't give these out). Once you are in setup mode, navigate to network/ethernet/TCPIP, and make your changes...One item of note...if you say "YES" to the "obtain IP for engine selection, the Fiery will assign a plus 1 adddress to the controller. This could cause problems if this IP is already in use. We normally ask the IT contact to give us 2 sequential addresses so we don't have any issues. To finish, simply exit out of the menus and the Fiery will re-boot. Emujo
