View Full Version : IR 6000 ERROR CODE FIX?
ybnews
12-21-2012, 02:38 PM
I cannot re-set my error code E000005-0000
Tried several times.
Here's what I do...
*28*
COPIER
Screen flashes
*FEEDER* 1/1 < ERROR >
FEEDSIZE -----
No on screen options are available
Any suggestions on what to try next?
Thank you in advance.
Dana Lewis
montana
12-21-2012, 03:08 PM
Here's what I do...
*28*
COPIER
Screen flashes
FEEDSIZE
Dana Lewis
hi....try this...*28*copier>function>clear
but you have a malfunction in the fixing web.....good luck:)
dan7777
12-21-2012, 03:43 PM
Here's what I do...
*28*
COPIER
Screen flashes
FEEDSIZE -----
Dana Lewis
Try and reboot and immediatly go to *28*. Replace the web if low. There are two counters to clear. COPIER>COUNTER>MISC>FIX-WEB and COPIER>COUNTER>DRBL-1>FIX-WEB.
ybnews
12-21-2012, 04:26 PM
I tried that as you instructed. No go.
Here's what's happening...
I hit *28*
Then COPIER
Display screen appears with highlighted options below.
I can get into those highlighted options.
However, Display options across the top row are not responding to my touch.
Therefore, I cannot get into "Counter" or any other functions in the top row.
I suspect an issue with the touch screen.
Any other suggestions?
p.s. I checked the cleaning web. It is about half used up.
Thanks.
vigour
12-22-2012, 02:34 AM
Your touch panel is out of adjustment.
You cannot clear the code until the panel is calibrated or replaced.
Follow the instructions below.
http://www.copytechnet.com/forums/canon/60612-adjustment-display-5870-a.html
