View Full Version : wrinkle in A3 size only in IR 3025
Hi,
Merry Christmas to all,
I have a problem in IR 3025 with finisher S1, the machine in A4 size working very well but when copying on A3 size from the cassette or from the bypass tray, the paper wrinkles in the end of the sheet but no jamming occurs, only wrinkle,
I changed the pick up, feed, separation rollers & fixing film assy, but nothing changed the wrinkle still occurs,
plz let me know your opinion about this,
Regards
ernesto
12-24-2012, 01:49 PM
Hi,
Regards
Hi,
you can try to adjust this.... Level 2: copier > adjust>fixing> fx-fl-sp (+3)
http://www.copytechnet.com/forums/canon/63197-wrinkled-paper-ir4570.html#post279158
all the best
blackcat4866
12-24-2012, 02:36 PM
Worn pressure roller and bearings is a possibility. =^..^=
Hi,
all the best
Hi
Merry Christmas
thank you very much the problem solved by change the fx-fl-sp to +3.
but can you explain this fx-fl-sp what is the function of this if change the value from 0 to +3.
what it means??
blackcat4866
12-26-2012, 02:33 PM
Hi
Merry Christmas
what it means??
FX-FL-SP is a fine adjustment of fixing film rotation speed, as can be seen on pg 16-43 of your service manual. =^..^=
zoraldinho
12-26-2012, 03:19 PM
The rotation cycle of the fixing film is monitored to control the fixing motor to a specific speed.
When the fixing film rotates and, as a result, the reflecting member positioned in the loop of the film approaches the speed sensor, the machine detects the rotation
of the fixing film.
18770
