View Full Version : Miscellaneous How remove toner cart on IRAC 5051
benerin
12-27-2012, 04:39 PM
Hello everybidy.. have a good day..
I have some question regarding on how to remove toner cart even it's not yet finished. I have other machine (same model) at are not working anymore but still have toner in cartridge I want to take that toner and to transfer on other machine which same model..
Thank you inadvance.. :)
zoraldinho
12-27-2012, 04:51 PM
This is procedure for Canon trained tech.If you are not,call one.
In Service Mode Level 2 make the following change. COPIER>OPTION>DSPLY-SW> T-CRG-SW. Set T-CRG-SW to a 1.
Exit Service Mode and perform the following:
In User Mode, enter SETTINGS AND REGISTRATION> ADJUSTMENTS/MAINTENANCE> MAINTENANCE> REPLACE SPECIFIED TONER.
skynet
12-27-2012, 05:01 PM
The instructions for removing the toner bottle manually if the machine is dead, should be in your service manual.
JustManuals
12-27-2012, 08:38 PM
If you can't remove the toner cartridge which is the most basic of all functions, you should call a trained authorized Canon technician.
HtH
Paul@justmanuals.com
Yes, I have the service manual if you want to buy it, email me.
benerin
12-28-2012, 04:24 AM
Thank you Mr. Zoraldinho,
You right sir, I'm not trained Canon technician. prevouisly i'm Sharp & Xerox technician technician for almost 20 years now, only this time i"m started this brand,
Again Sir thank very much.. Hopefully next time you can help again, hehehehehe
zoraldinho
12-28-2012, 10:38 AM
Depends on you.;)
