View Full Version : How to Set adf Canon ir2535.
makmee
12-28-2012, 01:45 PM
Hi all,
I've seen some of these problems.
Adf copy of the document is missing.
Placed on the document glass full.
Thanks for your help.
zoraldinho
12-28-2012, 03:45 PM
More info please! Did ADF detect document? How do you mean missing copy?
Are you a tech?
makmee
01-18-2013, 02:58 PM
Are you a tech?
Some parts are missing.
on adf
19001
on Platen Glass.
19002
Still do not.
I like this
zoraldinho
01-18-2013, 05:20 PM
Check ADF adjustments and paper feed rollers.Read PDF....
19003
arielcanon
01-19-2013, 12:49 AM
what's your document size to be copied on ADF? sometime we need to set on service mode for different size for copying from ADF. e.g: switch from A4 to FLSC
semsros
07-28-2016, 11:23 AM
Dear All
This is looking like my problem, My machine canon ir2535 v120, when I copy document A4 or A3 size on ADF it is cutting like Letter size, if I copy document A4 size on platen is ok.
please give me some idea to fix it
thanks you
Hi all,
If it's happening when using the glass then adjust the height of the dadf. I've had a few of these, replaced original sensors on the first one to no avail. The height needs to be adjusted and the dadf squared, then the original sensors under the copyboard glass will read correctly. This is the only model I've needed to do this on, worked on at least three I can remember.
dame1933
08-10-2017, 03:10 AM
Dear All
thanks you
DID anybody find a way to fix this problem? I still had this trouble
teckat
08-10-2017, 05:40 AM
Service Mode>SCAN>SCAN READER>OPTION>BODY>SENS CNF = 1
Power cycle machine.
To make the value of SENS-CNF stick after the Copier is rebooted, the following needs to be set in service mode.
SCAN > SCAN SW > SW06 > Bit2 to 1
Also, to enable the correct paper selection, change the following setting of the paper size
group.
SYSTEM > SYSTEM Numeric > 057 to 3 for inch configuration
1: AB configuration
2: A configuration
3: Inch configuration
4: AB / Inch configuration
charles
08-10-2017, 11:59 AM
Dear All
thanks you
pls reset the copier by the services mode
dame1933
08-30-2017, 06:03 AM
group.
1: AB configuration
2: A configuration
thanks very much bro, its really work
teckat
08-30-2017, 02:49 PM
37481welcome:cool:
