View Full Version : Miscellaneous bizhub 920 pro
NEOTECH
01-05-2013, 08:35 PM
hi everyone i have a problem in adf for bizhub 920 pro sc 60-03 i replace adf board but now problem is when i make copy in adf paper was exit in adr try but adf motors still rotating and copy not come out i open copier side door machine will stop and i found paper there i cant under stand what happen with this machine. if any one have a idea plz help me.
RRodgers
01-05-2013, 10:54 PM
Sounds like you missed a connector to me.
methogod
01-06-2013, 09:31 AM
I have brand new ADF units if you need one.
KM7155
01-06-2013, 12:10 PM
was the leading edge hit something? if not, i would bet the paper path sensor faulty.
methogod
01-06-2013, 01:04 PM
i would check i/o mode sensors on DF.
also make sure its not a odd firmware issues, that may have been fixed in a later version. New-board may be old firmware.
Re-seat cables, i would make a copy form the glass, make sure nothing is wrong anywhere else.
When you replaced board, did you unplug from wall? i have seen weird stuff with older machines, when adding/replacing parts or consumables while power is on.
Mick01
01-07-2013, 03:48 AM
Did you do the ADF sensor sensitivity adjustment when you replaced the board? In the service manual there is a "List of Adjustment Items" when replacing a part. It outlines what adjustments need to be made and in what order.
Hope this helps.
