View Full Version : C203 Wont print with Account track on, "No sscount set for group auth..."
Jnr
01-11-2013, 01:12 PM
I have a Km C203 its been working away fine with account track, then randomly two weeks ago it stopped printing and says " No account set for group authentication"
I have done a firmware upgrade. It prints when you turn the account track off or when you put users authentication on. Allow print is set.
Just a weird one and was wondering if someone had seen it?
EarthKmTech
01-11-2013, 07:29 PM
if its happening with PDF's you need the computer user to update to the latest version of acrobat reader.
Yes, i've had the above issue before.
Also, check obvious things like that the driver is the latest version available, either way, as per always, its going to be the computer/network/servers fault.
Mr Spock
01-12-2013, 01:16 AM
Check the printer properties for a preset code that may be overlimit or been removed.
SmellsHot
01-15-2013, 05:13 PM
In the printer properties, under configure, the "auto" check box is checked. Uncheck this and problem solved
