View Full Version : Bizhub 423 series upgrade memory for i-option
Gergő
01-22-2013, 09:46 AM
Hi Colleagues!
Does anybody know what type os memory could i use in Bh 223 sa upgrade memory for i-option? I know the UK-203, but in computer store it would be cheaper if I knew the exact type.
Thanks for your help
Gergő
emujo
01-23-2013, 02:07 PM
You could always pull the rear cover off and actually look at the installed chip...specs should be on the original memory, and the upgrade chip will be the same. Parts manual might give the specs also. Emujo
Gergő
01-23-2013, 04:26 PM
Upgrade memory is only 1GB instead of 2GB standard memory. In C224 series both of them are 2GB.
emujo
01-23-2013, 08:05 PM
Good info...thanks, I was only thinking about the type of memory DIMM/SODIMM/Speed etc...not the size. You are correct. Emujo
