View Full Version : BIZHUB C353 BLACK SCREEN
jvargas
01-27-2013, 05:14 AM
Hi, i have a problem with this machine, only in front of the copier i can see a red blue and orange, together, and the star botton is orange, the customer was printing 20 copies in 12 X 18 special paper, and only 19 copies go out. And the machine is dead, i change the power supply, the dc board, and the board that have de memory ram, the panel and nothing happen, the machine not warning up, no fans, no motor, nothing , but the boards are receiving the signal, because i can see the leds on, thanks for your coments,.
EarthKmTech
01-27-2013, 05:47 AM
replace the RAM, that's all it will be.
You should recover the other parts as they are not required to fix this problem.
jvargas
02-01-2013, 04:19 AM
thanks, i fixed the problem, i change the board that contains the memory dimm. the machine is ok now
