Minolta DI620 - code c-0540
  • samir
    Hi everyone,
    Could you please help me in solving the problem i got with my copier. it's blocked and gives this code: c-0540.
    Thank you very much in advance.
  • wagon
    Village Idiot
    • Dec 2006
    • 654
    Are you a technician? If you are not a technician it is unlikely you will have the skills to safely diagnose and fix the problem your machine has. It may be better to call someone who knows what they are doing.
    If you are hitting your head up against a wall it always feels better when you stop.
    • samir
      help
      thank u. Do you know if it's easy to solve.
      • wagon
        Village Idiot
        • Dec 2006
        • 654
        The problem you are having could be very easy to solve BUT if you get it wrong and miss something the end result could be a fire. Really.
        • mitchl
          • Apr 2007
          • 501
          Its a thermistor set signal problem, I saw this years ago and normally once a trouble reset is done the problem goes away............ But then again Ive had to replace the A board to fix the problem in other cases.................. I once had a customer try to take care of this problem themselves and set their building on fire and as they ran from the flaming building they didn't realize that unauthorized people messing with the trouble reset button releases a pack of wild dogs which ate them as they ran from the aforementioned flaming building........ The moral of this story is don't screw around with your copier unless you know what you are doing!
          • wagon
            Village Idiot
            • Dec 2006
            • 654
            Precisely what I was trying to say! Better for the machine not to work at all than to blow up and kill somebody.
