View Full Version : Buzhub C451 scan to email via gmail smtp?
mungooz
02-01-2008, 08:15 AM
I was wondering if anyone has been able to get scan to email using gmail's smtp server on the Bizhub C451?
I've been able to do it on a Bizhub C252 at the same location where the C451 is, but when I use that same configuration on the C451 I get a "server tx error." I was wondering if anyone ran into this issue as well and if there were able to resolve it.
Steve0
02-01-2008, 09:52 PM
Bizhub C451 scan to email via gmail smtp?
I think you already know Gmail server using 465 port.
Here is the TIPs.
E-Mail TX (SMTP) Setting - ON
Scan to E-Mail - ON
E-Mail Notification - ON
Meter Count Notification - ON
SMTP Server Address - Check and smtp.gmail.com
Port No - 25
Check Use SSL/TLS
Port No. (SSL/TLS) - 465
Connection Timeout - 60 sec
Max Mail Size - No Limit
Admin E-Mail Address - YrName@gmail.com
Device Mail Address - YrName@gmail.com
Authentication Setting
POP Before SMTP - OFF
SMTP Authentication - ON
User ID - YrName@gmail.com
Password - YrPassword
Good luck
mungooz
02-02-2008, 07:37 AM
That configuration will not work on the C451. It will work on the C252 but not on the C451. This is an issue with the C451. At the moment, the only work around is to run MS IIS or some other SMTP relay that doesn't need SSL/TLS with authentication.
climbguy
04-03-2008, 07:32 AM
I actually have a C252 and am having trouble getting the scan to email feature to work right. I tried to imput all the settings listed above and am still have problems. Do i need to list anything for the domain and are there any other settings or configurations I need to know in order to get it to work properly.
thanks!
