View Full Version : 7155/65 warming up, no code
superfly
02-12-2008, 10:42 PM
I thought i would share this with you guys-
If you ever run into one that constantly says 'warming up' and never comes ready or throws a code, the fuser connector in the back of the machine is likely broken.
or one of the heater lamps is burned out, or a cover is open somewhere??? my starting point would be to remove the lamps and ohm them out.
random
02-14-2008, 06:05 AM
Pini9061
02-14-2008, 10:05 PM
if you have this code try to replace the TLD sensor under the drum
best reg
pini
Sjeuf
02-21-2008, 09:46 AM
there is a microswitch under de fixing release lever ,confirm the right position of the lever,if this is good, check de switch good luck
i believe you are thinking about the 7050/7055. a 7155 does not have that switch.
