View Full Version : konica minolta c650 fiery
antoney suresh das
07-02-2013, 06:16 AM
Hi Guys,
I have a bizhub c650 a used machine the fiery for some reason is not along with the machine . Now the network access is disabled now if I need to use the machine without the fiery what are the adjustments to be made to enable the network without the fiery.Help guys!
thanks
bizhub1
07-02-2013, 12:11 PM
In service mode, change controller setting to 0
antoney suresh das
07-02-2013, 02:17 PM
thanks bizhub 1 a little more in detail i am a Ricoh guy
princef18
07-04-2013, 08:52 AM
You'll need to go into the service mode --> System 2 --> Image Controller setting --> Controller 0
Then restart the machine. It should be able to have network access now.
antoney suresh das
07-04-2013, 09:39 AM
Hi Prince,
i checked the 550 had i believe a external controller was there but not there anymore .When i checked system 2 the controller icon is'nt there.i guess some setting has to be unselected pls guide
johnyb
07-04-2013, 09:50 AM
You need the little jumper board that you take off to fit the fiery.
princef18
07-04-2013, 10:10 AM
You might have to wait for a while for the Image controller setting button to show up. I don't know why it does that. But it eventually pops up. Poke around the service for a few mins till it appears. :o Also try to restart the machine a few times.
I had a case like that a few weeks ago. Eventually it showed on the screen and I changed it back to Controller 0.
