Desert Rat
07-22-2013, 08:04 PM
:confused:
I got this call as a "Fuser problem". I inspected the fuser, it turns easy and looks used but not
trashed.
Power up and code SC670 is displayed. Defined by the book as "Engine start up error"
Then it sez "The ready signal from engine board is not detected".
"Defective engine board"
"Replace engine board"
This is my first look at this model, does this happen often?
Will I need the SD chip to save stuff on?
I did not see a procedure in the book to enter the service mode. From what I can tell from the book
it is a matter of going through the menue and finding the service mode? Then what? press ok?
The book also said to re-seat connectors before replacing boards. I can do that today may be.
I got the book after taking the call and I am trying to figure out a couple of things before going
back.
DR
trashed.
back.
DR
