View Full Version : Ricoh MP 7001 light copies/prints
mntech
07-22-2013, 11:52 PM
I can tone it up by force adding toner in SP mode and it looks great for 100 copies then starts to go light again.
Usually the machine wont ask for toner it it will just stay at grey prints rather then black, even tho I will tone it up and set the TD initial to where its density should be.
I change drum, blade, and developer. After developer replaced it ran for about 500-1000 before going light again.
Any ideas?
I'm thinking it might be because of the aftermarket toner or TD sensor? It seems to consume more toner then it replenishes, but never reaches a toner end condition.
I can't remember if I've tried setting toner detection to pixel count or if I'm thinking of a different machine. But all I know is there is no problems with the mechanical workings of the toner loading system.
Thanks,
-MNTECH
Venom
07-23-2013, 12:50 AM
possibly the toner filter screen on the dev unit has fallen apart and waste toner is now contaminating the developer
kannuki2
07-23-2013, 01:21 AM
Check the classification on the toner supply assembly for broken mylars
Tonerbomb
07-23-2013, 01:39 AM
Any ideas?
Really??? aftermarket toner and you have toner supply and image quality problems....... Probably soooo......
Might have screwed up the toner hopper also....... and pluged the vent tubes..................
ptrflrs
07-23-2013, 02:05 AM
Good suggestions above. Well known issue on this series, mine all go light eventually. There is recent firmware regarding light copies. You might have to reset pm counters after updating or replace drum and developer again. Aftermarket toner might still be the culprit, though.
Iowatech
07-23-2013, 02:14 AM
Kind of sounds like they aren't making enough prints for this machine. If that is what is happening here, the toner addition system isn't running long enough to keep up with toner usage.
If that's the case, the best thing to do would be to swap that machine out with one that is better suited for their needs. If that can't be done, you might try reducing the value of "toner feed time" in service mode. The machine will never be totally right, but it will work a good deal better.
mntech
07-23-2013, 04:17 AM
Thanks for all the feedback!
I'm going to look into the firmware and possibly switching to genuine toner.
They actually run the machine pretty heavy when they do run it.
I can't remember the meter, but I think the machine is pretty young.
And I don't believe anything is wrong with the hopper, filter, tubes, or anything because when I force add 1 time it is instantly better for a good 150 copies.
It seems more like the td sensor wants a lower concentration of toner to be satisfied, seeing as it goes light but never reaches a toner end or near end.
I'm going to take a look at it tomorrow to see if I can rule some things out.
I know aftermarket toner is not recommended, I always run aftermarket in the 1075 - 2060 series machines with out any problems, but I also know that certain ricohs can be picky.
Thanks again for all the feedback.
mntech
07-23-2013, 04:32 AM
I keep telling my boss that the aftermarket toner will cost us more in the long run.... on service calls, replacement parts, travel, etc.....but unless I can prove the aftermarket toner is the culprit he will continue to use the stuff. I was a factory trained Ricoh tech, and no Ricoh dealer I know would dare use aftermarket, but now working for a smaller company, we have to save money wherever we can.
totoro
07-23-2013, 05:53 AM
I'm going to say that the aftermarket toner is the problem, but just curious as to what your vsp and vsg readings are.
Eric1968
07-23-2013, 08:22 AM
Your boss should know that when you have to drive for an hour to a customer a few times for copy quality problems, the benefit of selling after market toner is gone. Customers also are not happy when you have to visit them 3 times a week.
Codex
09-15-2015, 04:53 PM
picked up this old thread, because i have exact the same problem with our machines (Aficio 1060 to MP 8000), We use only original Ricoh TYPE 9002 Toner, and i'm sure this is the problem....we got a kind of unofficial"confirmation" that something is wrong with this toner, but nothing sure, they make tests on some machines since two or three months......in our machines the problem is the same, with a new developer the machine runs for 10 or 15k copies , than starts to make light or grey copies and at that point everything we did (Firmware, PCU, various regulations, PM Parts), dont resolve nothing or resolve it only for a week or so......This is just for information, i asked here on the forum but it seems that this is an european problem (i know for sure that others have the same problem , Germany, GB, France.....)
I repeat, this is only for information
mntech
09-15-2015, 10:09 PM
I never did solve the problem.
We switched to oem toner and redid developer, but the machine would still go light after around 500 copies, tried tweaking a lot of toner settings to get it to load more as it was being consumed, but never fixed the issue. My next step was going to be to replace the whole dev unit, but we ended up replacing the machine.
-MNTECH
logrady2331
09-15-2015, 10:21 PM
There is a tech bulletin about this very problem. Don't know how to attach a file here, but bulletin is "D131,D132,D133 - 008. Dated 6-2-14. ALWAYS run OEM toner ONLY in this machine. Make sure firmware is at recommended levels and go through the tech bulletin and you should make some headway. Under usage on these boxes will give you fits. These things are BEASTS and are made to run hard. I havehad a couple that were underused. The bulletin covers that scenario. ALL mine if the field (about 150 of this series) never undertone anymore. Good luck and let us know what fixes it.
Zaxxon
09-16-2015, 05:52 AM
Could you provide the bulletin ind another way, by mail? Then I could attach it for other to se and learn.
imihm
09-16-2015, 07:12 AM
Any ideas?
Thanks,
-MNTECH
Hi there...
I wonder whether there is an ID senor in this machine ...if so replace ...
ricoheng
09-17-2015, 07:19 PM
the martini is overheating,there is a tech bulletin on it, update engine firmware and system firmware engine@ at least 1:74.01 & system @ 1.23.
these introduce sp3-990 and turns the fan on to a faster spin and can be adjusted to stay on for upto 4hrs after copier finishes a job,you definetley have this fault if you have toner spilling into the catcher at the front of the pcu and the dev is still in life.i only know about genuine toner though.Also dont forget the rear filter gets clogged and to clean the doc blade gap.
logrady2331
09-17-2015, 07:37 PM
ZAXXON, pm me with an e-mail address. I have the tech bulletin downloaded and will e-mail it to you.
Codex
09-18-2015, 01:19 PM
The first thing we did was this firmware update and turn the fans on, cleaning the gap under the doctor blade and cleaned/replaced the filtes but the situation after almost 6 months is exactly the same!!, the only thing that helps is to change developer........i'm sure that the problem is the damn TYPE 9002 Toner, last year we had the TYPE 6210, and everything was ok......Something is wrong with this (in our case Made in France) toner
Codex
09-18-2015, 01:33 PM
Can you post the BUlletin here please???
THX
Would be helpful for us to have more data, 3-103 readings...(when the machine is copying bad.....) also clean all developer unit.....the alluminium frame into the unit, and the magnetic roller must be like a mirror.....sometimes drum shaft and electrode plate contact of drum shaft must be polished.
barratec
09-18-2015, 03:50 PM
[QUOTE=Codex;489321]picked up this old thread, because i have exact the same problem with our machines (Aficio 1060 to MP 8000), We use only original Ricoh TYPE 9002 Toner, and i'm sure this is the problem....we got a kind of unofficial"confirmation" that something is wrong with this toner, but nothing sure, they make tests on some machines since two or three months......in our machines the problem is the same, with a new developer the machine runs for 10 or 15k copies , than starts to make light or grey copies and at that point everything we did (Firmware, PCU, various regulations, PM Parts), dont resolve nothing or resolve it only for a week or so......This is just for information, i asked here on the forum but it seems that this is an european problem (i know for sure that others have the same problem , Germany, GB, France.....)
I repeat, this is only for information[/QUOTE
Italy too!!
Codex
09-18-2015, 06:08 PM
Italy too!!
I write from Italy......
