View Full Version : Miscellaneous Ricoh MP 4001 - waste toner bottle
gifter
07-23-2013, 12:19 PM
Hi, could someone tell me if that machine have a waste toner bottle? If it has, than where?????????????
Pls some foto or where to search, my machine is sending all the time "waste toner full..."
3bok3bok68
07-23-2013, 01:16 PM
Hi, could someone tell me if that machine have a waste toner e? If has, than where?????????????
Pls some foto where to search, my machine is sending all the time "waste toner full..."s
Yes there is waste toner... open the right side cover you will see transfer unit, is that the waste toner...
gudluck...
redneckstylin
07-23-2013, 04:12 PM
lol goodluck make sure you have around the machine a lot of garbage bags laying on the floor gonna be alot of toner mess
Eric1968
07-23-2013, 04:35 PM
Most of the times the waste toner sensor is covered with toner, so the machine thinks the waste toner is full. You can switch this message off by setting SP2-960 to 0. This disables the toner overflow sensor.
JustManuals
07-23-2013, 07:33 PM
Paul@justmanuals.com
gifter
07-24-2013, 09:19 AM
i have some pics because i cant find this sensor :( could someone tell me where to search that thing?
215342153521536
Imprestik
07-24-2013, 10:06 AM
The above photo's are not where the waste toner catch is.
Again open the right hand side, on the duplex unit you have the transfer assembly, remove the transfer belt off the assembly, you will then find 3 screws which are underneath the transfer belt assembly you take off. Vacuum the cavity of the transfer unit housing, done waste toner is empty
gifter
07-24-2013, 11:32 AM
i think i found it :)
Question how to take out that transfer belt on pictures? I know where the 3 screws are but i dont know how to take off belt from the duplex. Next question i give nr 3 on picture to a part of transfer belt is that this sensor for waste toner?
2153721538215392154021541
Bantams
07-24-2013, 03:22 PM
If you lift the little black lever on picture n3 you can remove the unit from the machine.
skynetto
07-24-2013, 04:11 PM
Its fun tryin to teach an end user how to empty a waste tank. Next thing will be how to reset counters?
gifter
07-25-2013, 11:59 AM
Thx to 3bok3bok68 (http://www.copytechnet.com/forums/members/3bok3bok68.html), Eric1968 (http://www.copytechnet.com/forums/members/eric1968.html), Imprestik (http://www.copytechnet.com/forums/members/imprestik.html) and Bantams (http://www.copytechnet.com/forums/members/bantams.html) :) i did it machine works fine without alert :)
