View Full Version : CQ Ricoh MP4000B
Waliul
07-23-2013, 12:32 PM
Hi,
There are black background on Ricoh Aficio MP5000B copier. After servicing the machine
2 to 3 days its working fine & then its appearing again same problem. Please let me know
how to solve this problem.
With best regards.
Waliul
Cipher
07-23-2013, 01:39 PM
The dev roller is probably fully coated black.
JustManuals
07-23-2013, 01:41 PM
Paul@justmanuals.com
Waliul
07-27-2013, 09:40 AM
Hi,
The development roller is not coated black. Even this is not over toning problem.
The problem is appearing after 2 to 3 days & then after servicing its working fine.
Please let me know the solution.
With best regards.
Waliul
TonerMunkeh
07-27-2013, 10:25 AM
Are you using OEM toner and the correct developer? B296 9640?
zsoltee0001
07-27-2013, 12:02 PM
http://www.ricoh-support.com/tempfiles/RD009024a.pdf
2. Make the following SP mode changes:
- SP2201-01 (Development Bias): From 560 to 660
- SP2201-02 (Development Bias for ID sensor pattern): From 400 to 500 "
http://www.ricoh-support.com/tempfiles/RD009037.pdf
1. take off the toner bottle from the machine
2. print/copy while appears the "toner empty"
3. clean the developer roller, clean the waste toner unit, toner bottle unit.
4. change the sp modification
5. check the sp 2.001 (charge voltage) set the default 1.500 V !!!
zsoltee0001
07-27-2013, 12:48 PM
upps...you cant oopen it
andy227
07-27-2013, 04:48 PM
Define "servicing the machine", as in all service consumables replaced, or a "open,vaccum out and clean" service ?
Are these not the changes that were suggested, before they decided to modify the developer roller to a new coating version ? Is it the old version dev roller or the modfied one in the 'B' ?
