View Full Version : Do the new colour 03 models have SP5150?
nyates
07-26-2013, 07:48 AM
As title says, is all the info I'm after. If anyone has one in front of them to check it would be appreciated. We have one coming but not here yet. We are just wanting to check that we can still do banners with the 03's (C5503 etc) because every reference we've found to paper size is 600mm max length through the bypass. AND Before you jump in Paul, I have checked service manuals for an SP table on both Ricoh and Lanier and neither have that section in them. :p
Bantams
07-26-2013, 02:12 PM
21554
Yes it does and the SP Code table are in the Service manual called Field Service Manual Main & System Maintenance Multilingual on my ricoh.
As Attached and will self destruct in 12 hours :)
nyates
07-29-2013, 11:11 PM
Thank you, I figured it would but I had to check before I said a definite yes to my boss. I like your manuals too, everything is laid out nicer than ours and ours is just a jumble.
