View Full Version : Konica Minolta Factory Reset
Mr.Mario
08-02-2013, 08:08 PM
Good day Gentlemen/GentleWomen,
I had one of our tecs go to a Konica Minolta Bizhub 200 to install a new drum/developer, and instead of the resetting the counter, he did a factory reset.. and now after inputting the Ip address I can't connect to the web browser, any ideas why this might be happening, and more importantly how it can get Resolved. I'm able to ping the machine, so there is a connection.
any input would be greatly Appreciated
-Mario
blazebusiness
08-02-2013, 09:24 PM
-Mario First, so this doesn't happen to him again in the future.....the procedure to be followed when replacing drum & developer on the Bizhub 200 is the following. Take care not to skip any steps.
To Calibrate Dev:
Counter
Special Parts Counter
Clear PC Life
Clear IC Life
Touch END
SHUT OFF copier
change drum and dev
go in Tech Rep Mode:
Function
F8
Start - calibration takes 2 minutes
when start key turns green press End
That being said.....let's move on. By factory reset I assume you mean he went to "Initial mode" and did a total clear. The following data is initialized:
The following settings are cleared.
• Fax-related setting information
• Bulletin board setting information
• Transmission/reception log information
• Image data
• Network setting information
• Destination information
• Soft switch information
• Management-by-account setting information
• User authentication setting information
• Account/user counter
• Remote maintenance setting information
• FW download setting information
• Copy setting information (zoom ratio, paper size, erase width, paper source detailed
information, copy job program, bypass free size registration, etc.)
• CSRC setting information
So now you've got your work cut out for you..... the network settings and all the other items affected have got to be set up again from scratch. The total clear on this model should always be avoided when possible as it makes for a ton of work setting it all back up again.
Mr.Mario
08-02-2013, 10:37 PM
I didn't think that it was going to be easy, but it sounds to me that is worst than I originally imagened..
thank you so much for the input blazebusiness
