View Full Version : Error Code sc202 - MP5500
patrick_aab
08-05-2013, 06:33 AM
Just wondering if anyone has come across an sc202 error on these machines. machine gets power op panel has a dark screen with sc202 behind it. have replaced, Prism motor, IPU, I/O board, BCU and op panel individually and all together and still throwing up sc code on start up. any suggestions?
greyfox
08-05-2013, 07:13 AM
have you check the controller board?:)
TonerMunkeh
08-05-2013, 07:17 AM
Pull open all the trays, disconnect all options and try again. You might have a chafing harness on the LCT.
patrick_aab
08-05-2013, 07:38 AM
Tried turning on with main door, all trays, duplex unit, fuser/exit unit open, df and finisher unplugged and still throwing up error.
ruben
08-05-2013, 08:18 AM
In what order did you replace each part?
Imprestik
08-05-2013, 12:07 PM
1st, replaced the laser diode,
if it is still coming up, replaced the eeprom on the bcu
patrick_aab
08-05-2013, 12:56 PM
I replaced the prism motor and Ipu as a pair. Machine still threw up error. And then I replaced the bcu, IO board, operation panel, mirror motor and Ipu again all together at once still threw up the error code
1nevster
08-05-2013, 08:28 PM
You should really replace the Polygonnal motor and the BICU at the same time, doing them in sequence will blow the board again in a lot of cases.
Tonerbomb
08-05-2013, 11:39 PM
This wouldn't possibly be a post by the infamous aab1 under another name by chance???????????????????????????????????????????? ?????????????
kimbo
01-14-2014, 05:38 PM
Did you find the solution?
as I am having the same issue
At one of my customers,
Going to replace the ipu board and poly motor as a pair,
Fingers crossed
DIONISIS
01-31-2014, 12:14 PM
check LD UNIT-POLYGON MIRROR-LD REFLECTOR
kimbo
01-31-2014, 12:47 PM
Thanks DIONISIS replaced the PSU unit and the machine is working great now!
So I should have dug a little deeper to start with,
But thanks all the same!:)
