View Full Version : Miscellaneous paper accordion
Working on a C352, I'm getting an accordion look on the paper on the #2,3,4 trays. It's about 5" down does 4 accordions then 4" good then 2 more. It does not do it on tray 1 or with the bypass.
JustManuals
08-14-2013, 07:19 PM
Paul@justmanuals.com
blackcat4866
08-15-2013, 01:22 AM
jam codes?
wseyller
08-15-2013, 01:28 AM
Sounds like something in the vertical transport area near tray 1 and 2.
What are the paper sizes and types in all your trays.
Sent from my Galaxy Nexus using Tapatalk 2
No Jam Codes,
paper size tray 2 8 1/2 x 11, tray 3 & 4 11 x 17,
JR2ALTA
08-15-2013, 04:13 AM
Loop timing?
copier addict
08-15-2013, 04:14 AM
The only thing all three of those trays have in common is the set of transport rollers attached to the second tray feed assembly. That is where I would start.
wseyller
08-15-2013, 11:32 AM
Try setting all trays up with the same paper. Make sure paper type settings are all identical and then test all trays again. Ive been fooled before into thinking an issue was limited to a certain tray when the issue was for example a fuser unit.
