View Full Version : Miscellaneous how to delete job on job list
as i was printing on konica minolta 450,the machine just stop printing.i checked the network connections are all ok i cant print from
my laptot,saying job cant print.i have turn on and off,steel cannot print.but demo page can print and all that.
how do i delete job that i do not need anymore on job list.
pls help me
copier addict
09-09-2013, 01:43 PM
Have you deleted it from the print queue on your computer? Do that first and then delete it from the machine.
Hope this helps
emujo
09-09-2013, 02:21 PM
Print jobs (other than secure/print to box, fax RX) are stored in RAM. Turning power off should delete the job. But if this doesn't accomplish it, you should be able to see the job from the job status menu on the LCD. Select it and delete it. A solid blue light might means that you have a corrupt job and you may have to do a data clear to get rid of it. Emujo
when i was printing through network on my laptop,th machine print so many copies,while on printing,i send another print
the machine cannot print anymore,the network connection is totally ok.
i checked to see if their is hard drive on the machine,but i couldn't see any drive.
maybe the job list or job history is full,need to delete.
but i dont know how to delete old job that i dont need anymore,so i can have more free space,so i can send new print.
please help me.
if i apply data clear,the machine will continue to copy ? am scared if i do it, mybe the machine will not work again
SmellsHot
09-10-2013, 12:30 PM
If you go to the machine, it should have job list on the upper left corner of the display. TOuch this and it will bring up all active jobs current and in the queue....touch and delete
