View Full Version : C552 offsets the colors
avecosat
09-12-2013, 04:44 PM
Hi I have a C-552 that offsets the colors. I tried with the transfer unit and the black unit, the problem is intermittent and it's driving me crazy. Have you any idea , thanks.
Note: the translation is from google, sorry.:rolleyes:
nvram
09-12-2013, 07:12 PM
Hi, check the idc shutter mechanism, if the linkage is stiff, the sensors will remain covered while the door is closed.
Jazzwcs
09-15-2013, 05:55 PM
Couple of things to try:
Try cleaning the write unit off. If you have any developer dumping it will get on write unit windows and cause this. You may have to pull write unit out to clean it off properly.
If you are getting the oil can light with P-14 code, do the skew adjustment reset procedure for the write unit.
If you are getting the oil can light with P-21 or P-22 codes, check and clean IDC sensors and make sure the shutter is opening closing properly.
avecosat
09-16-2013, 08:33 AM
Thanks to all , I get the code P-31 and I have the trouble code C225B/C ( Black PC motor ) .
Jazzwcs
09-16-2013, 05:22 PM
With those 2 codes you are looking at the main drive assy now. May need to replace it.
mo0651
09-16-2013, 08:49 PM
Are the colors off only when copying or printing multiple copies? If so check the fuser loop sensor located on the frame below the fusing unit. It sticks and causes offsetting colors.
JustManuals
09-16-2013, 11:51 PM
Paul@justmanuals.com
avecosat
09-17-2013, 04:52 PM
I changed because was broken but still the problem , now I´m going to change the M18 Black Pc motor because the troble C-225B is for it .
nvram
09-20-2013, 08:44 PM
Hi p31 is soilage on the main drive encoder sensors, when left unchecked, the problem develops into 225b, this can only be resolved by replacing the dcpu, but make sure you clean the sensors otherwise you will over time have to replace the dcpu again.
