View Full Version : Problem Konica Minolta Bizhub 223
copyshop.suceava
11-02-2013, 12:12 PM
Hello I have a problem with Konica 223 print has 2 black stripes, which I think are in the oven, roll scratched, is in the picture attached below
You can buy the roll separately or the oven should be changed altogether?
ps. Excuse my English2274222743
blackcat4866
11-02-2013, 02:28 PM
Yes, you have a bad heat roller, also known as fuser roller. Konica Minolta sells these fusers as a unit. As far as I know, there are no aftermarket suppliers of individual fuser parts. You'll have to buy the assembly.
Let me guess. You've got about 240,000 copies on that fuser? That's about all I can seem to get from the bizhub 223, 283, 363, 423 series. They are supposed to yield 500K but never do. =^..^=
JR2ALTA
11-02-2013, 04:43 PM
Their rollers have been getting gouged for ten years, 200s,500,423s doesn't matter.
Not redesigning the thermostats shows a total disregard for quality. It seems so simple to fix.
copyshop.suceava
11-04-2013, 08:56 AM
the printer have 519k
so there are no aftermarket suppliers of individual fuser parts ?
CraigW
11-04-2013, 03:07 PM
That is a pretty good run for one of these, have had some with marks at 100k and less.
We had 200-350s that would run 500k+ perfectly..... these not a chance.
Thinking about trying the +5 degrees on one that we replace new and see how it goes.
copyshop.suceava
01-09-2014, 09:24 AM
I understand that this roller would be compatible with the KONICA MINOLTA 223
http://www.ebay.com/itm/Upper-Fuser-Heat-Roller-for-Konica-Minolta-Bizhub-350-/231059582360 (http://www.ebay.com/itm/Upper-Fuser-Heat-Roller-for-Konica-Minolta-Bizhub-350-/231059582360)
has anyone done this operation to change the roll?
after I opened and cleaned, those black streaks are not so pronounced even after 550K pages, but I would like however to change the roller
brent
01-10-2014, 01:57 AM
with 500k at the original fuser? are you sure it has not been replaced before? also just a thought if you bought one on ebay. are you overseas? make sure that it has the correct market area for your region.
also. I had to replace several at right at 100 k. for some reason. horrible design. and the fusers are expensive. the bizhub 350 fusers lasted longer for me. with half the price.
brent
wseyller
01-10-2014, 03:42 AM
After you cleaned it of course the streaks are not so pronounced. But you still have coating missing as it is worn down to the substrate. Without the coating the toner is just going to build up on the worn down area again instead of all of the toner staying on the paper. Very soon it will start streaking again.
The fused has probably been changed before. Never seen one get anywhere near that page count.
Sent from my DROID BIONIC using Tapatalk
copyshop.suceava
01-10-2014, 09:35 AM
I bought the multifunctional, counter 0 pages, and never changed fuser unit
cypcopier
01-13-2014, 03:06 PM
hi
you can find heat roller and press roller as well on market you have not to buy the fixing unit
