View Full Version : Jamming bizhub 350 adf jam, totally lost
pager727
11-20-2013, 07:22 PM
I have a bizhub 350 with the df-605, it is jamming intermittently, i have replaced the feed tires and sep tire and now at a loss.. any ideas?
Thanks!
copier addict
11-20-2013, 08:55 PM
If you could let us know where in the DF the jams are occurring and/or the jam code, that would be very useful in trying to troubleshoot your problem.
Darren
JustManuals
11-21-2013, 01:02 AM
http://www.justmanuals.com
paul@justmanuals.com
pager727
11-21-2013, 03:26 PM
it happens right before the transport rollers, i believe the one way gear on the transport rollers is slipping
Shadow
11-21-2013, 05:16 PM
you will need to remove the shaft completely and the bearing as well.
take some emery cloth and lightly scuff cross ways on the shaft to remove the glazing.
clean the one way bearing with alcohol and the end of the shaft as well.
reassemble the unit and test operations.
I can't remember if there are 1 or 2 one way bearings in that particular DF, if there is more than 1, do them all.
this will help improve the paper feed in this model DF.
rahadyan himura
11-22-2013, 12:12 AM
Thanks!
maybe your problem from drive section, you can check (4344 5059 01) TORSION SPRING at rear RADF, i face this problem and found the torsion spring is broken. checking at drive section and you can find your solution.
i hope this can help you
rahadyan
ameritech
11-22-2013, 07:10 AM
I had a bushing on one of the roller shaft that was worn down. I had to replace bushing and the shaft. Thr Only
Issue I had with with the 350 adfs.
fixthecopier
11-22-2013, 12:52 PM
There are 2 photocells detecting entry and exit. If they are dusty, it will jam.
