View Full Version : Annoying Konica Minolta Bizhub C360 squeak...
Soteria17
01-10-2014, 12:51 AM
Like the title says it's squeaking near the fuser I've done everything I can find it but just can't seem to get it. I do not think it's coming from the fuser itself. Any suggestions would be greatly appreciated. Never had a squeaking problem like this before...
brent
01-10-2014, 01:43 AM
squeeks are pure hell. honestly I would swap out the fuser if it sounds near the fuser? etc
rule that out if you have one handy
just my 2 cents
brent
copier addict
01-10-2014, 01:47 AM
I had a squeak in one of these and it turned out to be the registration assembly. I had to remove it and lube the bushings. That solved the problem.
Hope this helps
Darren
JR2ALTA
01-10-2014, 02:45 AM
Is it a loud screech after the last sheet exits?
wseyller
01-10-2014, 03:35 AM
Usually those white transport idler rollers are squeaky bastards. I agree if it is near fuser then I'd be trying a new fuser first.
Sent from my DROID BIONIC using Tapatalk
Dougtech
01-13-2014, 05:53 AM
Hard to diagnose a squeak unless you are there to hear it.
Try swapping fuser.
Otherwise I tend to start removing a gear that drives a particular unit and see if it goes away when that unit loses drive. sometimes a trick if it only does it while copying, but listen close before it jams...lol
mjunkaged
02-07-2014, 10:25 PM
Squeaks are really my least favorite / easy thing to fix! Little ventriloquist inside the machine makes it tough to even go by where it 'sounds' like it's coming from!! I agree, isolation is key!
copierwhisper
03-02-2015, 05:10 PM
JR2ALTA, I have one that gives a loud screech after the last sheet, do you have an idea on what is causing the screech?
allan
03-02-2015, 05:17 PM
Its probably in the reverse exit unit or the fuser retraction after the job ends.
Soteria17
03-02-2015, 08:48 PM
Thanks guys. Still don't know what was causing it. It worked itself out...lol
ivovb
03-04-2015, 08:31 PM
Check recycle of transfer belt. There are several versions of belt fighting toner blocking recycle pipe.
BR
