View Full Version : FK502 C353
mrfuser
02-10-2014, 10:56 PM
Do you know if the FK502 fax kit is the same on the C352 as on the C353?, or is the FK502 the same for all FK502 kits regardless of machine installed into?
Kelly
ck1
02-11-2014, 12:58 AM
As i know is Fax board is same , only the mount kit :( too bad
Synaux
02-11-2014, 06:13 AM
What?
JustManuals
02-11-2014, 10:18 PM
What?
It sounds to me that the board is the same across machines, but the mounting kit is different. That's what it sounds like to me anyhow. My $.02 cents FWIW. (For what it's worth)
HtH
Paul
ck1
02-12-2014, 06:15 AM
What?
The fax dard same as C250 , onlt the mount kit ....
Hansoon
02-12-2014, 08:57 AM
One could McGyver a box or similar support for the fax kit FK-502 but the problem is that interface board which is in the mount kit MK-711........
Hans
copytechman
02-13-2014, 03:17 PM
Will confirm, a C203-253-353 series machine requires the MK711 mount kit (which has 2 slots, for fax or usb) needs to be installed on the back of a c353 series for fax to function. The FK502 itself is the same across the board. Only the mount kits typically differ.
Regards!
A.
emujo
02-13-2014, 04:28 PM
Does anyone else think it's funny that this poster can't understand what the previous poster said.....I'm sorry, if this is the best you can do with typing, then I automatically put you in the "moron" category. Emujo
copier addict
02-13-2014, 07:48 PM
What's wrong? Who hasn't wanted to mount a fax dard at some point? Olnt, make sure nobody sees you. lol
ck1
02-14-2014, 01:58 AM
Just wrong typing and not checking only ... I know your eng very GOOD..... :(
EarthKmTech
02-14-2014, 10:40 AM
The actual FK-502 fax cards are all the same, no matter what machine you put it into or it come from ensure you flash the firmware prior to starting to using it.
I keep one in the car from a wrecked machine at all times for testing purposes.
If you're talking about mount kits well no, they're very very different and specific to the engine your intending to install it into
