View Full Version : Fiery IC-401
Scottyj
02-21-2014, 06:28 PM
Hi,
I recently purchased a bizhub c350. Can I use this as a network printer without the need for a fiery IC-401 print controller. i.e does the bizhub c350 have an internal controller?
It is only required for general office printing.
I have another c350 with an IC-401 controller however this seems to be dead. (not booting up/no power).
If I was to get this working could it be simply put onto the new machine?
emujo
02-21-2014, 08:30 PM
Not sure of the older Fierys, but on C353 and newer, you must let the MFP know the Fiery is installed through service mode...So on the one C350 you have a controller that doesn't work, on one you have a Fiery you can take off. I would think that as long as you set the Image controller settings correctly, you can remove the Fiery (there is a standard controller built in) and swap it with the non working Fiery. Again I assume the one with the non working Fiery is up and running using the embedded controller, so you will have to make a image controller setting change here also. Emujo
Scottyj
02-22-2014, 10:59 AM
Thanks Emujo,
On one c350 (older worn out machine) I have a fiery thats not working.
And on my newer c350 I dont have any external controller i.e fiery IC-401.
How can I tell if the newer c350 has an embedded controller?
methogod
02-22-2014, 11:22 AM
C350 has on board controller, see below...
Standard Konica Minolta PCL print controller with 350 MHz processor and 256MB of standard memory...
you can swap the fiery...
24056
Scottyj
02-22-2014, 11:32 AM
Thanks methogod,
What drivers would I need to run onboard controller for osx & win xp?
Blizzoo
02-22-2014, 12:44 PM
Without Firey check in Tech.Rep -> System Imput->Peripheral Setting ->Without Controller.With Firey set Controller 3
Scottyj
02-22-2014, 01:45 PM
Thanks guys,
I will try this out on Monday
