View Full Version : Error Code Please help me.......this problem ......
chadson
02-27-2014, 02:29 AM
hi guys.
yesterday, i was update my Fiery Fiery X3eTY2 65-55C-KM 2.0.....when i get restart is appearce error code.24137 24138
i can not printting.
please fix my error code.
thank you a lot Mode and everyone...
chadson
02-27-2014, 03:39 PM
hi guys.
helpppppppp
habik
02-27-2014, 04:03 PM
helpppppppp
You need 7 things:
1, Stop shouting and think!
2, Get a Service Manual for the Fiery
3, Get Fiery USB Flash Tool
4, Download again!! Fiery Software v2.0
5, Get USB Key 2 GB and format it and put the Fiery Software on it using USB FLASH TOOL!
6, If you have the Fiery Service Manual read again the procedure.
7, Go to step 1
PS. Get in touch with Paul@justmanuals.com
Mick01
02-27-2014, 10:58 PM
Hi,
I agree with Habik, there was an issue with the reload.
One thing to note the system software is too big for a 2gb usb stick. minimum 4gb is required.
You can also try and run the installer on the V2 System disk with your computer connected directly to the fiery with a cross over cable. The installer has a step by step procedure to follow. I have had a faulty HDD cause these types of errors when trying to reload. A new HDD might be worth a try also.
Hope this helps to get you back running again.
habik
02-27-2014, 11:10 PM
Sorry about the usb stick! I am using it on everything got so used to it. Mick is right! Thanks fort that , Mick
Sent from my iDon't believe in marketing device using Tapatalk
chadson
02-28-2014, 04:12 AM
i install by Lan.....connect PC
chadson
02-28-2014, 10:09 AM
2416324162
please help me.....i can not print this file......
My copie could print file <2mb .......can not print file >4mb
thank you so much.....
DigiMan
02-28-2014, 05:26 PM
If im seeing correctly your file is a JPEG and as far as i remember CW cannot handle JPEG files.
chadson
03-01-2014, 01:35 AM
are you sure......i think that support any thing file.....
Please help me..............
