View Full Version : BIZHUB PRO C6500 error code c-3801
impimp329
03-27-2014, 06:50 PM
I just got this machine a couple of weeks ago and it had just been serviced by Konica when it was at the previous owner's shop.
I noticed an error code as I was trying to get a rush job out. Can anyone offer a quick solution as I need to get this project out today!!!!!
JustManuals
03-27-2014, 07:22 PM
This Parts & Service Manual can now be purchased for $14.77 and downloaded immediately from:
http://www.justmanuals.com
Paul@justmanuals.com
Tech80
03-28-2014, 12:52 AM
This is a under temp code from Temp sensor 1 (TEMS/1). You should check your thermistor, clean it. Then you have to reset the code.
To reset: Go to DipSW 3-1 and set to 0.
You may have a bad sensor or heat lamp.
Hope this helps.
jmv
03-30-2014, 04:25 PM
maybe the bearing is off the fuser rollers
i have this probleme and i replace bearing the fuser roller 1
