View Full Version : konica 7222 not print function
wiedu
04-02-2014, 08:45 PM
hello people
I have 2 copiers konica 7222 with Print controle IP 432.ich have device with laptop USB anschließen.Treiber I use konica 7145 (IP-432) in windows7 (64bit).
After instalie driver test print from a copier is functioning properly.
in 2 unit also konica 7222 print unfortunately with IP-432 will not work the?
I have menu-test print from IP 432 and the function., I also gewechzel Print controle IP 432 of funtion but gets left without erfog.
Questions jemann know the problem?
Print controler IP-432 functions, the problem of copiers?
Heffen For everyone will be much thanks
pepper38_cnd
04-03-2014, 12:38 AM
I would like to help but I think something was lost in the translation?
wiedu
04-03-2014, 06:05 AM
We controle IP-432 has 2 photocopiers from konica in 7222 with printer.
we have print test below(at the bottom) windos 7.problem is only of one photocopier print funtion leave test Windows.
Other photocopier also konica in 7222 with IP-432 print no test Windows???
I already have around do not dip other IP-432, however, also function??
ask, man already know problem??
Problem of device(appliance)??
we thanks nicely for everybody heffen
mrwho
04-03-2014, 01:41 PM
If I got it right, he has two machines, one prints fine and the other doesn't.
Both printing via USB?
Maybe a defective controller? We need more details - if you try to print via network, does it work? Are you able to access the controller menus on the non-printing machine?
If you swap the machines, does the fault move with the machine?
wiedu
04-03-2014, 07:11 PM
Yes, You are right . I to connect network
printer controler work, I have printed menu controle IP 432.
I will try again later to check
When I print copier function say for you.
I thank you for your hiffe
