View Full Version : Error Code LS-505 error code C-1203
Joseph.ARM
05-21-2014, 08:12 PM
Hi everyone,
I have an LS-505 installed on a Bizhub 1200P, on start up the printer displays an error code of C-1203. I have the option to disengage the main stacker and only use the sub tray. I've swapped the alignment motor and the sensor, but I'm not sure what to do next. Any suggestions?
Thanks,
Joseph
mikeena
05-21-2014, 09:15 PM
LS-501/LS-502/LS-505, C-1203 (SC76-03) or C-1204 (SC76-04) at power up. The SC76-xx codes are indicated on the bizhub PRO 1050 series.
Solution
PROBABLE CAUSES:
1. The Grip Conveyance Sensor Adjustment has not been performed.
Note : The LSCB may have just been replaced. Please refer to attached LSCB Update documentation.
Perform the Grip Conveyance Sensor Adjustment (procedureis listed in the LS-50x section under ADJUSTMENT/SETTING/MECHANICAL ADJUSTMENT).
2. The Holder Claw (Grip) is damaged or missing.
Reinstall or replace the Holder Claw (p/n 15AV 5050 1).
3. Alignment motor (M7) has failed.
Replace M7 (p/n 15AV 8001 0 )
SPECIAL NOTE : Solution contribution by Gregg Gallant and Cesar Jimenez, Production Print/SSD
Joseph.ARM
05-23-2014, 03:39 PM
Thank you for the info. I performed the adjustment per the manual and I'm still receiving the error code. The grip looks to be in good shape. I have another stacker I can pull a motor from. Is there anyway I can test the motor before a pull it?
mikeena
05-23-2014, 10:55 PM
sorry im a little slow today yes there is go into tech rep mode go into i/o mode and do
68-9
68-10
turn them to 1==on this will test m-7
also
68-7
68-8
try these to they test m-4 the grip hope this helps
Joseph.ARM
05-27-2014, 04:52 PM
Don't apologize, I appreciate the help. M7 sounded kinda weird, so I manual moved the stopper section to the rear. The tray lifted and it was fine, no error code.
Thank you for pointing me in the right direction.
mikeena
05-27-2014, 09:42 PM
glad to have helped you have a good one
