View Full Version : C252 scanning and stapling
climbguy
04-06-2008, 03:56 AM
Is there a way to get the BizHub C252 to stable? If so does it require some sort of attachment or accessory.
Also, I am trying to set it up for scanning. I found instructions here: http://www.copytechnet.com/forums/konica-minolta/7595-buzhub-c451-scan-email-via-gmail-smtp.html#post19887
However When I try to do that it doesn't work. Is there any special trick i need to know or is there anything else I need to know?
thanks!
mungooz
04-06-2008, 10:00 AM
In order to staple you need to have an attached finisher with stapling option such as the FS-514 finisher for that model.
As for the scan to gmail, those instructions are pretty precise. What is the error could or message that it is giving when the the scan doesn't go through?
redhotrob
04-06-2008, 02:22 PM
Staples using the FS-603 finisher also.
Konica Minolta bizhub C252 Accessories ¬ Konica Minolta Business Solutions (http://www.bizhub.biz/products/C252/accessories.php)
